It is currently Sat Jun 14, 2025 12:58 am
Post new topic Reply to topic  [ 148 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sat Aug 11, 2012 3:41 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Looks good, but why does it only have a few frets?
Pablo Picasso
PostPosted: Sat Aug 11, 2012 8:04 am
Good morning Peter,
This insturment, like many American folk insturments the design is derived from, utilizes a diatonic scale as opposed to a guitars chromatic scale. The diatonc scale contains only the whole notes of the scale whereas the chromatic scale contains both the whole notes and the half notes. Why the origianl designer added the F# fret to this insturment, I don't have the answer. I did add the 3rd fret (C) yesterday before the first coat of finish.
PostPosted: Sat Aug 11, 2012 9:05 am
Sheesh, you're almost done and here I am rebending the sides I screwed up [headinwall]
It looks cool though - looking forward to here what it sounds like.
PostPosted: Sat Aug 11, 2012 3:03 pm
I started with this one to get a good jump start to the challenge. Simple, cheap and easy to build. With that small soundbox they have a plunky, thin sound. A bit like a broken banjo. Fun to play though.
So I'm calling that one done for a total of $2. $1.25 for frets, $.50 for the finish and $.25 for the nails to hook the strings to. Are we counting the price of strings? I haven't seen those on anyone else's list yet.
So I've never built a mandolin, an archtop acoustic or an acoustic with a cutaway. So I started an archtop mandolin with a cutaway. The lumber is from the scrap pile and from a pile my friend Joe dropped off with me when he moved to Hawaii.
The douglas fir for the top was a stair tread that I saved after replacing an exterior entrance to a house. Out of five treads this was the only one with decent grain. The fretboard and headplate will be from a piece of jatoba flooring. The bridge will be the leftover piece from the wishbone part of the pickin' stick.
From Joe's pile, some reasonably flamed maple for the back and sides and a chunk of mahogany for the neck and end blocks.
PostPosted: Sat Aug 11, 2012 3:13 pm
So I started by cutting the top and back pieces to size and jointing them. Both will be slip matched as that's what you get when you scrounge. Then I made a plexiglass template and traced the shape onto the boards and cut them out on the bandsaw.
In this photo you can see the good side of the back. Yep, you're supposed to flip the template for the back.
PostPosted: Sat Aug 11, 2012 3:15 pm
Here's the top carved and awaiting thicknessing.
PostPosted: Sat Aug 11, 2012 4:12 pm
First name: Tony
Last Name: C
City: Brooklyn
Wow you work fast.
http://www.CostaGuitars.com
PMoMC
PostPosted: Mon Aug 13, 2012 6:30 pm
I got a bit more done yesterday. The top and back are carved and the tone bars are in. I haven't the first clue on how to voice one of these so I'm going to wander over to the mandolin forum and try to scare up Chris Oliver for some tips.
Here is the back.
And some brace work.
PostPosted: Tue Aug 14, 2012 9:35 pm
When you use this,
to do this,
you get this.
I missed the memo about using a cork tip on the post. Good thing for wet rags and clothes irons.
PostPosted: Tue Aug 14, 2012 10:44 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Regarding all the little dents: Yep, that will even happen on some hardwoods. I put a bunch of those on a carved, arched walnut back once. But, as you say, lesson learned, and the fix isn't such a big deal.
Patrick
PostPosted: Wed Aug 15, 2012 1:34 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Wow! You are cracking on with the work Steve! I can't believe how much you've gotten done so fast!
Looking forward to seeing/hearing the final products!
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Wed Aug 15, 2012 7:04 am
First name: Big
Last Name: Jim
How about a Vid on the " Using "this" to do "this" to get "this" Process ?
PostPosted: Wed Aug 15, 2012 7:59 pm
I had an hour to spare this morning so I fired up the pipe bender.
Dave F's words kept echoing in my head. "Cracking". Thanks Dave.
Wound up with this which will need some touch up. Might be a few days though, paying work is on the agenda.
PostPosted: Thu Aug 16, 2012 6:32 pm
Hey Jim,
I'm a bit video challenged, maybe Dave F can come over with his camera. I do have some stills for you.
You set up a dowel with a cork tip (see Filippo's pic above) centerd below a drill bit and secured to the drill press table. Mine is glued in a piece of 3/4" plywood and the plywood is screwed to the table from below.
Make a gauge block with the various thickneses called for in the carving of your top or back. The plans for this inturment called for 1/4" under the bridge, 3/16" for the bulk of the top and 1/8" for the edges. Since the edges were carved to 1/8" from the top side I'll only be using that part of the gauge for a handle. I made this on the table saw. A similar gauge was made for the back using it's proper thicknesses.
Use the gauge to set the drilling depth.
Mark the top with the area that you want drilled and make a bunch of holes.
Using your gauge reset the drill depth and make a bunch more holes.
You'll notice in the above picture that the 3/16" depth holes are drilled right up to the 1/4" depth holes. Don't do that. Leave yourself some space so you can make a smoother transition between the different depths. That will help tremenduosly with fitting the braces and help with the strength of the top. I don't think I over carved this one, I'll find out in a year or so.
PostPosted: Thu Aug 16, 2012 6:46 pm
With my carving weapon of choice it's good to have a downdraft sanding table. The one is made from some used hollow core doors, a used furnace fan and a 3/4' MDF top. Someone posted a plan for this here on the forum a few years ago. Rod True or Todd Stock or ???, not sure.
Said weapon, 4 1/4" angle grinder with a 60 grit flap sander. I think I'll order a scorp for the next time I do this.
Grind away until your close.
At this point I switch to some more civilized tooling.
Here it is all done and ready for braces.
PostPosted: Thu Aug 16, 2012 6:57 pm
First name: Big
Last Name: Jim
Thanks [:Y:] I kinda figured that was the idea , but seeing some info in pics helps .
PostPosted: Sat Sep 15, 2012 8:22 pm
I've been back at it an hour or so here and there for the past couple of weeks. Haven't been taking many pics as shop time has been sparse. Here are the highlights up to yesterday.
After I got the top braced, it was f-hole time.
Then I bound them in jatoba (cut offs from the Stick's neck). First time doing that, now I know what Todd Stock was talking (typing) about.
PostPosted: Sat Sep 15, 2012 8:32 pm
A little neck action. Mandolin... little neck... laughing6-hehe laughing6-hehe laughing6-hehe that's funny stuff. I slay me.
I cut the angle at the wrong point so I had to glue the headstock the way I don't like to have enough length. I'll get over it after I add a back strap.
PostPosted: Sat Sep 15, 2012 8:50 pm
I glued in this corner block,
and seemingly like magic, the box was closed, binding channels were cut and the neck was roughed to shape.
This is the binding jig I built for my arch top flat back electrics. Worked fine for this, I made a carriage out of 1x6 pine to hold the body level. There is just a big hole under there that is cut 1/4" in from the body outline and a piece of 1/8" birch plywood stapled the bottom.
PostPosted: Sat Sep 15, 2012 9:25 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That looks awesome. I like the shape a lot. What are the dimensions of the body, looks similar the size of the flat-top I'm making. Those f-holes are great. I'll have to resist the temptation to steal that shape.
Bryan Bear PMoMC
PostPosted: Sat Sep 15, 2012 10:06 pm
I like the look of it too. Bound f-holes look nice.
PostPosted: Sun Sep 16, 2012 2:21 pm
Those F-holes look great.
PostPosted: Sun Sep 16, 2012 4:31 pm
Filippo, you do make some handsome jigs and fixtures. What's with the rounded corners and dust collection? Don't you want to look like you went to war when you come in from the shop?
Bryan,
The body is 9 1/4" x 13 1/4" with a 7 1/4" upper bout and 5 5/8" waist. It uses a standard 13 7/8" scale neck. The plan was purchased from a guy in southern Illinois. Do a google search for "Don's Plans". He has plans for ukuleles mandos and others, they are fairly cheap and you get what you pay for.
The F holes are really just the standard ones adjusted a bit to loose those unsightly bulbs. It took about a minute with a pencil and a french curve to fix the mistake people have been making for centuries. Glad everyone approves.
PostPosted: Sun Sep 16, 2012 4:33 pm
Here is a nice shot of the binding process.
PostPosted: Sun Sep 16, 2012 6:10 pm
More neck stuff.
Fret slots.
Found a piece of 3/32"x1" steel in the shop so I cut it up to make a non-adjustable truss rod.
Ran the pieces through the thickness sander to clean them up. This takes a while as you can't take much off at a time or you will bugger up your drum.
Glued the two pieces in with polyurethane glue. The package claims the adhesive works on metal so I thought I'd give it a shot.
